raft layer question
Hi there,
I am using the prusa slicer 2.2.0 Win64 and would like to understand the raft layer a bit more. 4 years ago someone discussed that already, but did not work out a conclusion. I used 2 raft layers. The print itself uses 0.28 mm layers. The slicer does 0,2mm, 0,5mm (the 2 rafts) and than goes to 1mm! It does not make sense at all to me – but it did work – the printing object was 183mm and it did stick to the heatbed. Does anyone can give me an answer – why it does a 0,5mm layer high?
Thanking you
Stefan
if you can imagine it - if you can design it - you should print it!
Make the impossible - possible!
Postato : 23/12/2020 10:07 am
Topic starter
answered:
RE: raft layer question
solved.
Postato : 24/12/2020 8:13 am
