Raft after Height Range Modifier
Hi all, hoping you can answer this question I can not find any info on... If I add a raft under my model, after specifiying a bunch of height range modifiers, do the modifier height ranges all need to be updated? are the height range modifiers absolute layers, or "Object Model" layers?
Thanks!
Opublikowany : 30/09/2022 11:44 am
RE: Raft after Height Range Modifier
I have never used them. You could just test them without editing them and see if it works.
Opublikowany : 02/10/2022 11:20 pm
Height range modifiers are properties of the object you applied them to, the raft is added below the object. So the object gets lifted by the raft, so do the height range modifiers. No need to update anything, it will work as expected.
Opublikowany : 03/10/2022 2:20 pm
