Question about what parimeters you change when you change between layer heights
klaudijus_95
(@klaudijus_95)
Hi, I have a question on what settings do you change when you change the layer height bellow 0.2mm. I have been printing now for a while (just relatively new to Prusa & its slicer), but have always been printing on 0.2-0.3mm height and I have used pretty much the same setting for both of them with just some temperature changes on to the nozzle. However, going lower than that (bellow 0.2mm) decreases my quality of prints drastically, as it just gives more artifacts and rough surfaces. I have tried the stock Prusa slicer settings for heights such as 0.1mm with the same results.
Postato : 19/03/2020 6:59 pm
vintagepc
(@vintagepc)
Utenti
RE: Question about what parimeters you change when you change between layer heights
Me? Nothing.
That said, it is *very* important you have your filament diameter, extrusion multiplier, and K-factor for linear advance dialed in correctly. Lower layer heights make any over/underextrusion error that much more apparent.
Postato : 20/03/2020 11:41 am
klaudijus_95
(@klaudijus_95)
@vintagepc
Thanks for suggestions! I will try to work on those. I don't know, why it doesn't print well with stock settings for me tho
Postato : 24/03/2020 12:29 pm
vintagepc
(@vintagepc)
Utenti
Could be any number of factors. The stock settings are generics that should work for most cases but of course there are exceptions.
If you're still having issues after those calibrations, post pictures of the print surface and 3MF files for folks to review, then we can get better insight into the issues you're having.
Postato : 24/03/2020 12:38 pm
