PrusaSlicer bug slicing Pela Block socket panel?
Strona 1 / 2
hartzell
(@hartzell)
Not sure if I've stumbled onto a slicer bug or what.  Thought I'd ask.
I'm using PrusaSlicer-2.1.0+-201909160907 to work with models from the Pela Blocks project.  I've calibrated and etc, and generated a smaller socket panel for testing and etc by editing PELA-socket-panel.scad, exporting the STL file from OpenSCAD and importing it into PrusaSlicer.
When I print it, one of the holes is occluded.
Here's what it looks like after slicing:
Here's what it looks like when I import it (which matches what I see in OpenSCAD):
I've attached the STL file.
g.
Opublikowany : 01/11/2019 6:07 pm
hartzell
(@hartzell)
RE: PrusaSlicer bug slicing Pela Block socket panel?
Hmm, would allow me to attach the stl file.   Perhaps if I hide it in a tar file.....
Opublikowany : 01/11/2019 6:09 pm
hartzell
(@hartzell)
Ok, can't seem to attach the STL file.  Sigh....  Open to suggestions.
Opublikowany : 01/11/2019 6:10 pm
hartzell
(@hartzell)
Here's a link to the file, temporarily hosted: https://shrimp.alerce.com/tmp/PELA-socket-panel.stl
Opublikowany : 01/11/2019 6:37 pm
Hi George, if you ZIP the STL, you can then attach the zip file
Opublikowany : 01/11/2019 8:29 pm
rmm200
(@rmm200)
"One or more of your objects are invalidly defined" according to 3D Builder.
Open your STL file with 3D Builder (a free Microsoft tool).
Import the object. 3D Builder will find that error. Let it fix it.
Save your file. It will replace your original.
Now when you slice, it will be perfect.
Opublikowany : 01/11/2019 9:10 pm
hartzell
(@hartzell)
Let's try attaching a zip file.
Attachment removed
Opublikowany : 01/11/2019 9:42 pm
hartzell
(@hartzell)
Posted by: @robert-rmm200
Don't have anything that'll run 3d-builder.  If the stl file is "bad", then I assume this is an OpenSCAD bug?
Opublikowany : 01/11/2019 9:43 pm
hartzell
(@hartzell)
@robert-rmm200 -- Can you diff the before and after versions of the STL file and see what's been changed?
rmm200
(@rmm200)
@george-h9
Above my pay grade. But I can upload my "fixed" stl.
Attachment removed
Opublikowany : 01/11/2019 9:46 pm
Why on earth do people post files in foreign-to-most-OS files. ZIP is the format. bin, jar, rar, gx, .ztar, 7zip, and similar formats are NOT common for 90% of the computer users in the world.  May as well not post them.
And, if you take to time to post something, at lease verify the file you are posting isn't empty. While I enjoy the occasional foo-bar, a bar folder is not exactly useful.
Opublikowany : 01/11/2019 10:15 pm
hartzell
(@hartzell)
I've opened an issue about this on the OpenSCAD site: https://github.com/openscad/openscad/issues/3114
Opublikowany : 01/11/2019 10:28 pm
hartzell
(@hartzell)
Thanks for the upload.  For some reason, I thought that these were text file that were diffable, but they don't appear to be.  Sorry for the noise.
Opublikowany : 01/11/2019 10:34 pm
rmm200
(@rmm200)
Posted by: @tim-m30
Tim, what are you going on about?
Nothing posted in this topic, by anyone, was empty...
Just curious - what is a "bar folder"?
Opublikowany : 01/11/2019 11:29 pm
I'm uploading multi-part zoo archives from now on, baby!
Opublikowany : 01/11/2019 11:49 pm
ssill2 i Sembazuru polubić
hartzell
(@hartzell)
FWIW, the folks over in OpenSCAD world don't seem to think that there's any problem with the STL file that's being exported.  Details here: https://github.com/openscad/openscad/issues/3114
Opublikowany : 01/11/2019 11:53 pm
rmm200
(@rmm200)
Tim - I found your Bar folder, posted by the OP. Makes more sense now.
Opublikowany : 02/11/2019 12:29 am
I remeshed that one octagon surface and the problem went away; but Meshmixer didn't flag anything.
Opublikowany : 02/11/2019 9:41 am
hartzell
(@hartzell)
Tim, apologies.  I'm a long-time unix user, my goto format, for a very long time, has been compressed tar files.  zip files are my odd men out.
I did, indeed, screw up when I created the file I initially posted in my GitHub issue.  Like I said, not a regular zip-per.  I'm human, I guess....   I dropped the file into a throw-away sub-directory because it drives me nuts when unpacking archive files mixes up their contents with the current dir's bits.
Opublikowany : 02/11/2019 3:13 pm
hartzell
(@hartzell)
Posted by: @tim-m30
Thanks for poking at it.
Does that point to a bug in the OpenSCAD output, or ???
Opublikowany : 02/11/2019 3:14 pm
Strona 1 / 2
