Prusament PC Blend Carbon Fiber Black, pccf
Seite 2 / 2
RE: Prusament PC Blend Carbon Fiber Black, pccf
I've used it with both types and didn't see an appreciable difference so it's more a matter of taste, I think.
Veröffentlicht : 10/10/2023 12:20 pm
Mike C
(@mike-c-3)
Thanks. If there is no difference in difficulty to remove the prints from the sheet without using glue, then I'll just go with satin it's the only one besides smooth that is in stock.
Veröffentlicht : 10/10/2023 12:30 pm
Mitglied
Be careful.  The glue stick is both a sticking agent and a release agent.  Many a user has ruined a sheet not using the glue stick.
Posted by: @mike-c-3
I have a role of this filament to use with my MK3S and I'd like to avoid using glue sticks. I do intend on getting a dedicated sheet for this filament. What, if any, is the best sheet to use if I want to avoid glue?
Veröffentlicht : 10/10/2023 1:49 pm
bryn51
(@bryn51)
I use glue stick mainly to aid removal of prints from the bed  without causing damage to the bed. It extends the life if the bed.
Without glue stick an impression of the printed object is left behind on the bed snd it never fades. With glue stick it just washes off.
The fact the glue also aids bed adhesion means I do not need to add a brim to aid bed adhesion also helps reduce print post-processing and cleaner finished products.
The cost is just the glue and a little time to apply the glue before printing.
Veröffentlicht : 10/10/2023 8:10 pm
bryn51
(@bryn51)
I go with the recommendations from the manufacturer Prusa. They lean toward the satin sheet.
I find it works well, I have all the bed plates, but satin works well, so I just use it.
Veröffentlicht : 10/10/2023 8:28 pm
Mitglied
This is what can happen:
Veröffentlicht : 10/10/2023 8:56 pm
Mike C
(@mike-c-3)
Thanks for the recommendations.
If I'm going to have to mess around with glue stick then I might as well first try with my smooth PEI sheet and maybe then I don't have to order a new sheet. According to the Prusa Material Guide this filament is OK to use on PEI if used with glue stick, so if I need a glue stick regardless it seems there is no point in getting a satin sheet.
Veröffentlicht : 10/10/2023 10:39 pm
richnormand
(@richnormand)
Speaking of Prusament carbon fiber  filament this might be interesting to some:
depending of your planned application as it is specifically mentioned.
REPAIR, RENEW, REUSE, RECYCLE, REBUILD, REDUCE, RECOVER, REPURPOSE, RESTORE
Veröffentlicht : 10/10/2023 10:53 pm
YVO
 YVO
(@yvo)
Mitglied
My experience with MK4, 0.6 obixidian nozzle, satin sheet (larger parts with glue stick)
1, Extrusion multiplier is set on 0,85 (Prusaslicers default is 1.04) to solve overextrusions.
2, @fuchsr quote “It likes to curl around the nozzle and requires some attention at the beginning of a print to remove oozing filament.“
I see the same behavior:
2A, during printing this is solved by change of Extrusion multiplier and nozzle is not collecting as much material as before (and leaving unwanted bulb on ramdom places of the part),
2B - beginning of printing - to remove oozing material especially before Z-axis calibration is mandatory for me, otherwise first layer would fail
Veröffentlicht : 26/07/2024 5:12 pm
ron-f
(@ron-f)
Posted by: @ivan-gavenda
Yes extrusion multiplier is about 0.85 when not dried but I found 1.04 when dried.
I already mentioned that here:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/prusament-pc-blend-carbon-fiber-black-pccf/#post-636186
Veröffentlicht : 11/09/2024 1:17 pm
vhubbard
(@vhubbard)
Is there a good alternative? Since Prusa has switched to this filament for some of their parts, Prusament PCCF has become unobtainium.
Veröffentlicht : 25/06/2025 5:54 pm
Seite 2 / 2
