Prusamen PLA Mystic Brown severe under extrusion - but supports print fine
Hello,
Just received new Prusamen PLA Mystic Brown, I wanted to print this model. I used 0.1mm DETAIL preset with Prusamen PLA set as printing material. I'm using Prusa MK3S+.
Print is severely under extruded , however the support material prints just perfect. Could someone please explain me what I'm doing wrong? The Prusament PLA is calibrated to be 1.75mm, It should not under extrude. Furthermore if the supports print completely fine, with no visible under extruding so how the other parts of the print fail?
Veröffentlicht : 20/01/2024 5:31 pm
RE: Prusamen PLA Mystic Brown severe under extrusion - but supports print fine
The statue model was floating in the air for some reason. Lowering it down manually fixed the problem.
Veröffentlicht : 21/01/2024 8:04 pm
