Prusa MK3s+ new prusaslicer color change failure
I have a simple rectangular case it's 92 layers about 18.4mm tall. I put a layer change in at layer 10. What follows:
1. printer stops for color change. Unloads filament.
2. printer won't activate load filament, after good ejection. The gears don't turn
3. just say yes to filament loaded with no filament loaded.
4. Printer throws a hissy fit. Slams around. Then asks to load filament again. With the filament loading correctly.
5. Print starts again but all the way at the top of the model.
That is where I quit the print. I have tried a few times with no success. Anytime I did it in the past it was fine. After the latest prusaslicer and firmware things seem to be getting wonky.
Files > Save Project as
