Prus Slicer 2.3
garethsnaim
(@garethsnaim)
Prus Slicer 2.3
Hi.
I like the paint on support stuff, however how do I have support material for just one or two items?
For instance I am printing out something where there are 12 parts on the bed, I only want support for one of those items, but the only way I can see to do this is turn on support then manually have to go over the 11 other items and paint on not to support.
Surely I can just select one item to have support?
Veröffentlicht : 27/12/2020 9:56 am
Swiss_Cheese
(@swiss_cheese)
RE: Prus Slicer 2.3
good luck with that, it's very poorly documented just like the support blockers and enforcers in 2.2 frankly, you would be better off just modeling your own supports. or use some other software.
If you really want to struggle try using multiple extruders with different material types on a single object.
The Filament Whisperer
Veröffentlicht : 27/12/2020 10:53 am
Lichtjaeger
(@lichtjaeger)
RE: Prus Slicer 2.3
You can adjust support settings for each part individually:
https://help.prusa3d.com/en/article/per-model-settings_1674
https://help.prusa3d.com/en/article/modifiers_1767
Veröffentlicht : 27/12/2020 11:42 am
