Problems with original Prusa silver PLA
Seite 2 / 2
stoofer
(@stoofer)
Re: Problems with original Prusa silver PLA
My problem filament I describe here was prusa silver that came with the printer. The diameter got so big in places as to cause jams:
https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f62/when-good-filament-goes-bad--t22879.html
Support identified it as from their old supplier, before they moved to making it in-house, and are sending me a new roll.
Veröffentlicht : 09/07/2018 12:25 pm
Protoncek
(@protoncek)
That's interesting...well,i can't rule out my filament, but since my jams happened on my local filament, too i can assume that this is probably not the cause of the problem. Since installing heatsink on extruder motor and keeping doors of enclosure open during printing jam didn't happen yet. I didn't install duct fan yet, but i have it finished and ready as a last resort...
Thank you for reporting this issue, it's important thing to know. I admit that i wouldn't think that width can be too big...
Veröffentlicht : 09/07/2018 2:48 pm
Protoncek
(@protoncek)
Latest update on this issue: problem still persists, although not so aften as before. I printed and installed new parts (R3) which supposely better cools heatbreak, but since now we have a "heatwave" with temperatures over 30 degrees outside i have frequent filament clogs, again on the same spot: right below gears. I have alluminium cooler mounted on extruder motor, but it still achieves quite high temps, so i guess next stage is installing fan as i mentioned before and hope for the best...
Veröffentlicht : 01/08/2018 4:04 pm
toaf
 toaf
(@toaf)
i had the same thing with my .05 Tardis. for fun use prusa control to slice it. for SCIENCE!
Veröffentlicht : 03/08/2018 1:37 am
Protoncek
(@protoncek)
Prusa control is a dead thing. Supposely prusa will incorporate a part od user interface in future releases of slic3r. In any way prusa control uses slic3r engine anyway. I could play with it, but i'm pretty sure that problem is too hot motor and nothing else. If motor reaches 55-60 degrees than gears pretty quick also reach that temperáture, and that's limit point for PLA where it becomes soft...
Problem are small things, where there's a lot of retraction with small forward push, so filament is traveling up and down practically at the same spot...
Veröffentlicht : 03/08/2018 3:30 pm
toaf
 toaf
(@toaf)
I do feel your pain. but when I went from slicer, to PC default .05 my tardis survived the print. I was thrilled when it got past the first set of door retractions. and it looks ok no (choking points)
Veröffentlicht : 04/08/2018 2:06 am
Protoncek
(@protoncek)
Interesting... ok, i can give it a try and see. The only thing i see here is that retraction settings are obviously different, maybe less agressive..
Veröffentlicht : 04/08/2018 9:51 am
Seite 2 / 2
