Problems printing thin object from Blender STL
Hello,
I have a model that I exported from Blender to STL, internal scale set to mm, export scale set to 1, but when I load it into slic3r it's terribly small. The height of my model is 3mm, but I also have sections which are only 1mm in height. I tried to scale it to 1000% but when I print, it only prints less than 1mm in height and of course missing details. The section which is 1mm doesn't even get printed. The model shows well in slic3r after scaling it with all parts. However, it only loads in STL format, I tried obj and slic3r cannot open it due to an error.
Any best known methods to print something this thin?
Thanks!
Napsal : 20/05/2019 2:00 am
