Problems not known
Basic
(@basic)
Problems not known
Hi
Again I'm here, having some problems I don't know how to address to.
This is my 4th attempt, and obviously somethings wrong...
Before the tries, I had to clean the complete hotend after PA filament made everythings nasty. Now, after reassembly this happens...
Also: when starting a print job now, the printer always starts by telling me I should change the filament... Why??
Thanks a lot, guys.
Respondido : 21/11/2021 12:41 pm
sylviatrilling
(@sylviatrilling)
RE: Problems not known
First layer calibration Z-offset is too high.
Mk3S+,SL1S
Respondido : 21/11/2021 2:00 pm
Basic
(@basic)
My z-Adjust would have been at - 1.475mm before.
I lowered it down to 1.625, until the extruder started jumping... and lifted back to -1.500mm.l (until jumping stopped).
Hope that helps (unless it's reasonably little difference in reach..? )
Thanks for your answer.
Why does my printer stops and prompts for Filament Change after z-Calibration/ before it starts to print the job? It does it since I updated firmware (V. 3.10.0)
Thanks again
Respondido : 21/11/2021 3:17 pm
Could be something in your startup gcode or the filament sensor is out of whack.
Would help if you saved the project from PrusaSlicer as a 3mf file, zipped it, and uploaded it here. This way we could see all your settings.
Respondido : 21/11/2021 3:29 pm
Basic
(@basic)
Yo. Thanks for reaching you a hand!
The zipped file is attached...
Meanwhile, on the print plate...
(im fighting, cleaning the paused result from time to time)
FDM-DL_011-temp
Respondido : 21/11/2021 4:21 pm
Basic
(@basic)
(after taken the Photo I raised the nozzle temp to plus 2 degrees)
The filament I use here is
FIBERLOGY PCTG
Respondido : 21/11/2021 4:30 pm
Basic
(@basic)
... all went hush so long, till that went in at Z=14.9
Respondido : 21/11/2021 5:05 pm
Basic
(@basic)
That glob built up, I want able to remove entirely -
So I again, got some layer displacement =(
Posted by: @kopplog
Respondido : 21/11/2021 5:26 pm
For one, in the 3mf project you have a color change at 0 mm ☹️ That's why you're prompted to switch filament. Just right click at the very bottom of the vertical slide in the preview and delete it.
Layer shift...
Can be many things. For one, the temperatures you've chosen seem ultrahigh for PETG but then again I've never used this particular brand.
I would also add a skirt to make sure anything stuck on the nozzle gets removed before the actual model is printed. And for PETG make sure the nozzle and heater block are as clean as possible.
And my check list for common reasons for layer shifts:
Pulley screws on X motor not properly tightened. One has to be tightened against the flat side of the motor shaft!
Belt not correctly tightened. Use this tension meter to get it right: https://www.prusaprinters.org/prints/46639 X carriage over-squeezed. Loosen the back plate on the X carriage axis.
Nozzle hit an obstacle. Some patterns such as grid have lines that cross within one layer. This can lead to little pile-ups at the intersection points, in particular if you have slight overextrusion, which in turn can lead to the nozzle catching at those pile-ups. See https://help.prusa3d.com/en/article/infill-patterns_177130/
Zip ties on the wire bundle on the back of the extruder not properly positioned, so they or the cables hit the model.
And lastly, make sure the steel sheet is super clean. Lots of hot water and dish washing soap.
Respondido : 21/11/2021 5:39 pm
Basic
(@basic)
Thank alot for your complete answer.
Will recheck!
Last glob/ooze built up at Z=41.9 (before Z=14.9, even before at Z=2.5,... first at Z=0.7)
Hope to get there eventually by retuning and checking list, thanks.
And thanks for that filament change entry...
Ps: Heatsink and all around it was super clean, even serviced it incl. servicing PTFE-Hose. No straps or anything else hanging down... What causes the ooze-buildup no idea. Thought maybe a faulty heatsink.
Respondido : 21/11/2021 5:55 pm
ssill2
(@ssill2)
in my experience with petg you get blobbing/boogers when the extrusion multiplier is too much.   I find that with petg, I usually have to do less than one, say .94-.95.   you can test this out at the printer by just tuning the flow during print.   the default if you go and tune during print is .95.  This is a good starting value if you're seeing blobbing.
Respondido : 21/11/2021 6:14 pm
Basic
(@basic)
Thanks.
I went from .95 at the beginning down to .94...
Think of getting even lower...
Respondido : 21/11/2021 6:26 pm
Basic
(@basic)
OK, thanks all.
I now will put this thread to :solved: soon
All seem working now - the reasons of the hickups were:
1) the multipler was put to high
2) the Z-displacement happened obviously through the built up of oozes/globs from time to time... And the printer head displaced after skating over that ones.
At the end I want to address that I took a default filament for Fiberlogy PETG... and tried to adopt it to my needs, as I use a slightly different material called Fiberlogy PCTG.
Not aware if there're settings out there my Prusaslicer runs WITHOUT Internet connection (as my whole pc isn't connected) -
and I really wanna emphasise Prusa again, to put Filament Default Settings online again as collections to download.
I'd appreciate very much
Respondido : 21/11/2021 7:06 pm
Basic
(@basic)
Hi again - found the problem!
I have leakage on my nozzle. So, I reassembled the nozzle improperly after cleaning!!!
Posted by: @kopplog
OK, thanks all.
Respondido : 21/11/2021 8:21 pm
Have you found the Prusa Knowledge base article on nozzle replacemet?
Respondido : 21/11/2021 10:06 pm
ssill2
(@ssill2)
Yes I made this mistake before after changing from a brass to a steel nozzle.
Posted by: @kopplog
Posted by: @kopplog
OK, thanks all.
Respondido : 21/11/2021 10:57 pm
