Problem with STL and Slic3r PE
Hi!
I'm trying to print a tiny box, and i don't know if the model is too small, or i'm not dialing the right settings, but when I try to slice it, it shows maybe 1 or 2 layers (see image)
I've tried slicing it with the stock settings of 0.2,0.15,0.1 and 0.05 [mm] height.
I uploaded the models to my personal cloud of mega.nz, so there's no risk of viruses (:
Lid: https://mega.nz/#!KQ4h3JZQ!EuT7-W8l_KioBY0ytMx87GCSZM2v6wETPQsIOcHVijY
Box: https://mega.nz/#!Pcxl0LaS!_5g4S9zaABKVqR_jl46j3Ul0OiPYP1xISgAQozDcAnI
Re: Problem with STL and Slic3r PE
Could be that the walls are too thin. I assume you are initially using the stock 0.4mm nozzle
Try using the 0.25mm nozzle profile for slic3r
And see if it then slices as you would expect
If so. Consider scaling the model to say 120% and try slicing again
Regars Joan
