Problem with printing Fillamentum Flexfill 98A
s0ny
 s0ny
(@s0ny)
I am currently solving a problem with printing Fillamentum Flexfill 98A. Model MK3s, PrusaSlicer settings for Filamnetum Flexfill 98A, layer 0.1 and 100% fill. I managed to make a few prints. Since some time, my printing is not going well and ends up more or less the same every time. I have tried all possible settings but I am unable to print. I did a complete upgrade to the MK3s+, replaced the nozzle, added cooling to the extruder, bought a drying box. None of this helps and I don't know how to proceed. Any ideas?
Napsal : 20/06/2021 12:37 pm
RE: Problem with printing Fillamentum Flexfill 98A
Is the filament wrapping around the extruder cog?
You have to back off the pressure until it is barely gripping the filament.
Napsal : 20/06/2021 4:39 pm
ssill2
(@ssill2)
not sure if it applies with flexfill, but I found with ninjaflex recently that sometimes you need to increase your temp.  Swiss_cheese and I ran into an issue recently where it appeared the ninjaflex came from the factory having already soaked up humidity and it required a higher temp to get it to print at all.  it exhibited the same kind of issue.  you might try higher temp or drying it.
Napsal : 21/06/2021 8:04 pm
ssill2
(@ssill2)
I actually have some flexfill 98 coming so I'll give it a try too when it comes in.
Napsal : 21/06/2021 8:55 pm
I've just finished a Flexfill 98A print for a boat owner in the local harbour - on my MK3 I undo the extruder idler completely then re-engage the screw, this time I took care to notice the point at which the cogs engaged the filament correctly ... only 3/4 of a turn of thread.
Yours will be different, you are looking for the pressure that only just grips the filament.
Napsal : 22/06/2021 10:00 am
ssill2
(@ssill2)
I did finally get this in and print a filament sample with it.  at 98A it's definitely the most rigid tpu I've printed with.  printed fine with built in profile.
Napsal : 23/06/2021 9:48 pm
