Problem with print dimensions by 0.2 mm
Kamil Ślopek
(@kamil-slopek)
Mitglied
Hello, I recently uploaded the latest software to my Mk3s printer and now I have a problem when printing a rectangular container, the dimensions in the X and Y axes were too small by 0.2 mm, instead of 60 mm, it was 59.8 in the x axis, and instead of 30 mm, it was 29.8 in the Y axis, in the everything was fine, I was printing with a 0.4 nozzle using petg, how could I correct it??
Veröffentlicht : 01/12/2023 7:06 pm
Robin
(@robin)
RE: Problem with print dimensions by 0.2 mm
Are you sure this is related to your firmware-upgrade? (Did you pint the exact same gcode prior to the update and it had the "correct" dimensions?)
Post the zipped 3mf-project-file from Slicer.
Veröffentlicht : 11/12/2023 3:03 pm
