Problem in printing a piece,
DANR
 DANR
(@danr)
Hi everyone,
I have a problem printing a piece, the radius that is on the bottom part, closest to the bed, is not good, the top part is good.
I am currently using Prusa ABS with nozzle 0.6mm, and the layer height is 0.2mm
I already activated the options, "extra perimeters if needed", "ensure vertical shell thickness" and used the layer editing from the Slic3r Prusa edition, but i can not solve the problem.
Can anyone help me?
Thanks in advance
Veröffentlicht : 27/07/2018 2:35 pm
Re: Problem in printing a piece,
You could try using supports from bed only
Regards Joan
Veröffentlicht : 27/07/2018 3:40 pm
Preview your print in Slic3rPE to ensure support is being generated up far enough. If not, you can try adjusting Print Settings->Support Material->Support material->Overhang threshold to a higher value, or Enforce support for first layers further up your print. You can read about my adventures with this same issue here. Martin.w15 had some good tips.
Veröffentlicht : 27/07/2018 4:09 pm
DANR
 DANR
(@danr)
Guys, thank you so much by your tips.
Previously, I had already achieved satisfactory results with petg, but I gave up using petg because i have difficulties in adhesion and dripping is irritating, moreover I feel that the abs is easier to print and gives more mechanical quality.
With the petg I used 0.3mm layer height, was that what helped to have a better piece?
In any way I'll try out your tips.
Thanks! 😉
Veröffentlicht : 27/07/2018 10:20 pm
