Prints crashing with PETG
raylo
(@raylo-2)
Not sure what is happening here, but I am having repeated print failures due to the Mk3S+ leaving a buildup in one spot into which the print head eventually crashes into.  driving me nuts.  I am using Galaxy Black Prusament PETG using Pruser slicer standard settings. The part prints perfectly everywhere else except where the blob forms or is dropped.  I redid the Z and first layer calibrations and it made no difference.  Any ideas what to try?
Best Answer by raylo:
it was the loose nozzle.  D'oooohhh.  Another lesson learnt.  printing perfectly again.
Postato : 18/07/2023 6:03 pm
Walter Layher
(@walter-layher)
RE: Prints crashing with PETG
Your part looks like you have problems with stringing. Did you dry your filament before printing? That is a frequent cause for problems with PETG.
Postato : 18/07/2023 8:05 pm
raylo
(@raylo-2)
I agree it looks stringy.  This is a 2 week old roll and I have never had to do any special drying with tons of PETG printing.  But maybe this particular color or batch is different?  I guess I can put it back in the bag with desiccant for awhile.  Meanwhile I am going to try the same print in PLA and see what happens.
Postato : 18/07/2023 9:22 pm
raylo
(@raylo-2)
The other data point is that I printed a previous version of this part with the same roll a few days ago and it printed fine.  So I bet you are correct that my filament got dosed with the recent humidity... even though I have the air conditioning on and indoor humidity is generally less than 50%.
Postato : 18/07/2023 9:31 pm
Walter Layher
(@walter-layher)
If you print PETG frequently getting a filament dryer or a food dryer (perhaps cheaper, but only for use with filament, not for food after using it with filament!) might be a good idea. You can see a clear difference in print quality after printing with PETG that has been dried shortly before. With PETG (no harmful evaporations) it might even be possible to use a kitchen oven at 60 °C to dry a spool for a few hours, just to demonstrate how beneficial the drying process is for print quality. Drying it with desiccant is much less effective.
Postato : 18/07/2023 9:43 pm
raylo
(@raylo-2)
Crazy thing is I have never had an issue like this with PETG before.  Maybe it's just summer.  IDK.  But having to dry filament every time I print will be too much of a PITA.  I guess I need to prototype more in PLA and maybe only bring out the PETG for finals.  Again, IDK.
Postato : 18/07/2023 10:31 pm
It's just a routine, every time I remove a spool from the printer I dry it before storing it sealed with (dried at the same time) dessicant.  That way filament can be selected and used from storage without needing to dry it first.
Postato : 18/07/2023 10:53 pm
kroneyd
(@kroneyd)
I'm having the same issue.  I re-calibrated the first layer mutliple times, changes nozzle temps and extrusion multiplier values but can't seem to get this issue corrected.  I dried the filament earlier in the week but I guess it could be humidity.  Any other suggestions would be greatly appreciated.
Postato : 19/07/2023 12:23 am
That's a suspect first layer; the picture isn't sharp enough to diagnose properly...
Run the built in first layer 'Z' calibration and show us the result *on the print sheet*.
Postato : 19/07/2023 9:44 am
kroneyd
(@kroneyd)
After 10hrs of drying at 149F - the same result.  This problem is quite vexing.
Postato : 19/07/2023 10:38 am
kroneyd
(@kroneyd)
Here are some more photos - including 1st layer cal photo.
Postato : 19/07/2023 10:52 am
raylo
(@raylo-2)
The same thing is happening with PLA. The print looks good except that the print head drops a blob or causes a buildup a couple of times during print.  I can pause the print and clip it off and resume.  Or if not it will crash permanently.
One thing I forgot to mention earlier is that I changed the nozzle right before it started acting this way. I have had the old nozzle off a couple times to clean it so I am familiar with recalibration... this time I just swapped the nozzle.  It is supposedly an identical E3D V6 nozzle.  maybe I'll put the old one (now cleaned again) back in and see what happens.
Postato : 19/07/2023 6:02 pm
raylo
(@raylo-2)
Hmmm... I just found that the nozzle was loose.  Tightened it up, now re-calibrating.
Postato : 19/07/2023 6:15 pm
raylo
(@raylo-2)
Postato : 19/07/2023 9:06 pm
