Prints acting as heatsink and corners curling
wes.w2
(@wes-w2)
Hello all. I have been having trouble with corner curling for a while, and while increasing my heatbed temperature has helped, I still get a little bit of curling even with brims and mouse ears (when you flip the print over you get little Y shaped pullups at each corner where the brim partially did its job.
I currently print with the bed at 70 degrees with PLA and I was starting to get concerned that the temperature might not be accurate, so I got a decent thermal measuring device and I realize now what the problem probably is.
My prints are acting like a heatsink! --- ok that should have been obvious, but the problem is that the heatbed is not warming up to compensate. The edges of my heatbed will be 70 to 71 degrees, but the areas right next to the print can be as low as 58. I believe that if I can get that temperature up to 65 or 70 and keep it there throughout the print I can get rid of this last bit of corner curling.
Any other ideas I should try aside from jacking the heat another 5 degrees ?
Prusa Mk3 with powder coated bed that has been scrubbed, cleaned, loved, and provided copious amounts of pure grain alcohol to protect its precious essence.
(FYI -- my first layer is as tuned as it is ever going to get -- I am fairly certain I am losing adhesion due to the parts acting like little heatsinks after this thermal measurement discovery --- and I am trying to make it work without using any adhesive ... it is like a matter of a pride at this point 🙂
Veröffentlicht : 13/01/2019 7:39 pm
Butterworth Design
(@butterworth-design)
Re: Prints acting as heatsink and corners curling
You're printing with PLA? I have a couple of questions/comments...
  • Why are you trying to print with your heatbed set so hot? 70°C is above the glass transition temperature of PLA. PLA will be soft and viscoelastic (deformable) at that temperature, so any PLA at that temperature will have a tendency to move.
  • PLA tends to stick well even to unheated build plates. That might not be true with a PEI surface (I've never tried to print on my build plate without heating it, so I can't say for sure), but a print surface at 45°C to 50°C on the Mk3 has been great for me.
  • Refresh the build plate with acetone, as stated in the user guide. Don't do this often, and don't let liquid acetone sit on the surface. Be gentle.
  • Did you try the glue stick yet?
  • PLA has a thermal conductivity of about 0.13 W/m*K. It is a terrible conductor. It would be a terrible heatsink. Also, the thing about a heatsink is, the heat has to go somewhere. It may be more likely that your thermometer (infrared gun type, I assume?) is seeing a wider area than you think, and is taking an average that includes both the build plate and the side walls of your printed part, which will of course be at a lower temperature than your build plate. It's far more likely that the PLA printed part is acting as an insulator for the build plate. The external surface of an insulator will be much closer to the ambient air temperature than whatever is being insulated.
  • MyMiniFactory (Functional Parts and Mods): https://www.myminifactory.com/users/butterworthdesign
    Thingiverse (Fun Designs and Remixes): https://www.thingiverse.com/uscbutterworth/designs
    Twitter: @USCbutterworth https://twitter.com/USCbutterworth
    Veröffentlicht : 13/01/2019 10:57 pm
    wes.w2
    (@wes-w2)
    1) Bed adhesion seems to be strongest on the powdercoated sheet at around 60+ C --- I thought my bed was underheated as referenced in original post so I walked it up and general bed adhesion is rock solid now until the plate cools and the different shrinking speeds pops it right off
    2) Yeah you definitely need some heat to keep the PLA on the powder coated sheet if oyu don't want it to shift
    3) Not really needed -- adhesion is pretty rock solid at the moment
    4) I am trying to solve this without adhesive, as stated in the original post -- it is a matter of pride because brim or mouse ears should be enough to stop this
    5) My gun has a dual laser system so you know exactly what circle you are measuring. the build plate itself is reading a surface temperature much lower near the parts, and it is a fairly nice curve away from it... 60 61 62 63 64 65 ... etc using very small measuring diameters (about a half a to a 1 centimeter circle) I have also tuned the gun for the heat emissivity of the powdercoated plate and it registers correctly ambient room temperature when cool.
    Veröffentlicht : 14/01/2019 4:07 am
    Nikolai
    (@nikolai)
    Sorry, but I don't understand that. It's like not using the right tools for your job.
    I've for example red Matterhackers PLA roll. This one has exactly the same problem. So I'm using very fine abs film for this filament. Problem solved.
    I suggest you either use adhesion helper (whatever you prefer) or get other filament brand. Playing with bed temperature will just bring you other problems.
    Often linked posts:
    Going small with MMU2
    Real Multi Material
    My prints on Instagram
    Veröffentlicht : 14/01/2019 6:38 am
    wes.w2
    (@wes-w2)
    As an experiment I have given it a quick acetone wipe, followed by a rinse with distilled water, then 99% alcohol rinse, lint free wipe with clean cloth, and will know in 8 hours if I have a different result.
    Veröffentlicht : 14/01/2019 7:10 pm
    Steve
    (@steve-3)
    I think that the part should act as an insulator to help hold the temperature. Maybe it is the cooling fan that is removing all the heat.
    Steve
    Veröffentlicht : 14/01/2019 8:04 pm
    John
     John
    (@john-6)
    More reliably - a drop of dishwashing detergent wiped with a wetish paper towel and then cleaned off with water and dried - NO fingers!
    i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
    Veröffentlicht : 14/01/2019 9:12 pm
    wes.w2
    (@wes-w2)
    Dishwashing detergent - that is part of my standard ritual.
    Ok -- after action report --
    acetone appears to have had an effect. The corner tips are no longer getting slight curling, so bed adhesion was improved greatly. I am still getting very odd temperature readings near the parts.
    I am going to do another print tomorrow and intentionally print near the bed corner to see what happens.
    Veröffentlicht : 15/01/2019 12:14 am
    wes.w2
    (@wes-w2)
    Steve
    You may be right. And the bed is not trying to heat back up because the heating bed is probably still very toasty even though the very surface of the powdercoated plate has become not so toasty.
    Veröffentlicht : 15/01/2019 12:15 am
    wes.w2
    (@wes-w2)
    Steve
    wes.w2
    (@wes-w2)
    I am giving butterworth answer credit since acetone did work to solve the curling. The temperature readings are still confusing to me -- but the actual printing issue was solved by bulletpoint number 3.
    Veröffentlicht : 15/01/2019 12:18 am
    Butterworth Design
    Rock on. Happy printing!
    Veröffentlicht : 15/01/2019 7:28 pm
