Printing with ASA
David Kennis
(@david-kennis)
Printing with ASA
Can some help me with this. I cleaned the printer. fasten all belts clean the rots. i have tha latest firmware.
I'm using Prusaslicer laters software. it's ASA from Prusa and using temp 260 and bed 110 degrees.
But i cannot solve the problem. the cirkels are not streat.
Publié : 06/06/2021 9:52 pm
Membre
RE: Printing with ASA
That looks like a layer shift.  Did you lubricate your bearings and is your grub screw on the flat side of the shaft on your motors?
Publié : 06/06/2021 11:09 pm
Swiss_Cheese
(@swiss_cheese)
definitely layer shift in the x axis
The Filament Whisperer
Publié : 07/06/2021 12:05 am
Dan Rogers
(@dan-rogers)
Looking closely at that picture, the first layer has definitely lifted off of the bed.  The item being printed is going to be a wack-job-of-a-warping-test.  I suspect that the warping is causing the layer shifts you are seeing.
Publié : 12/06/2021 6:22 am
David Kennis
(@david-kennis)
I did a cleanup of the machine and fasten the belts. First print wrong.
Then I exported the print from fusion 360. The file is much bigger and it takes 3 days in stead of 2.
And it looks much better now.
Publié : 12/06/2021 11:37 am
