printing problem? or slicing?
simon B
(@simon-b-3)
hello printing fam
i got a strange problem when printing a large object on the pictures you see a line after the top solid infill
i already changed the vertical shells perimeters to 4
the red pictures from mk3s+
the black picture from mk2
all sliced with prusaclicer
printed PLA
maybe someone knows a sulution?
thanks
when im printing a small part of the big part the result is better
also some strange wave in the top solid infill 1 one corner
prusaslicer the wall is straight
in this picture you see the problem
this black print got the same problem on my mk2
prusaclicer makes a top solid infill to the outside wall
this was sliced with cura
cura keeps the wall with infill, without a solid layer in between
the result with cura is much better but i dont like the rest of the print quality with cura
Veröffentlicht : 17/10/2021 9:50 am
Mitglied
Slicing
I suspect this is a slicing problem.  Upload a 3MF File and we can check it for you:
Veröffentlicht : 17/10/2021 12:58 pm
simon B
(@simon-b-3)
file
thanks for the reply
https://mega.nz/file/ahEQFb6R#_bWQcm3gYbHj0NuV3fT4vDkbEhxKSL7t3NAhaoH4ytk
Veröffentlicht : 17/10/2021 1:54 pm
sylviatrilling
(@sylviatrilling)
RE: External perimeters
You could try it with enabling 'external perimeters first'. See https://help.prusa3d.com/en/article/layers-and-perimeters_1748#external-perimeters-first
Mk3S+,SL1S
Veröffentlicht : 17/10/2021 5:52 pm
