Printing problem: filament stop extruding
Ratthy
(@ratthy)
I have a problem with my print, every time I print lately, the filament get stuck in the extruder. I remove the filament, and then reload it, and everything is ok.
I have purchase cleaning finalement, pass a few time in it, and still not printing correctly.
This morning, have try a Cold Pull cleaning, it was print correctly for almost two hours, and then it restart to block.
At this point, I does not know what to do next.
I will try again the cold pull.
The picture, is my first cold pull cleaning result.
Publié : 02/01/2020 8:06 pm
Ratthy
(@ratthy)
RE: Printing problem: filament stop extruding
Problem find, I have change the nozzle, and everything is going fine.
Publié : 12/01/2020 10:29 pm
rmm200
(@rmm200)
Next time this happens, look at your unloaded filament.
The extruder should have a good "bite" on the filament, and leave tooth marks.
Barely marked - tighten the extruder tension screw one revolution.
Too tight, deep tooth marks - loosen that screw one turn.
Big chunk chewed out of the filament - clean your nozzle and / or print hotter.
Publié : 12/01/2020 10:35 pm
Ratthy
(@ratthy)
This was of the result of never cleaning the nozzle, and many day of printing. The nozzle was to dirty, with a cold pull, the filament broke before the nozzle almost every time.
I have try many thing, but never print hotter.
now, I will clean the head after a few print.
Publié : 12/01/2020 10:45 pm
