Printing PCBs with a 3D printer
Lvet
 Lvet
(@lvet)
Hello,
I was wondering if it possible to print a PCB directly on a piece of glass using a 3D printer.
Are there conductive filaments that could be used for this?
What do you think?
Cheers
Luca
Opublikowany : 30/11/2019 9:29 pm
towlerg
(@towlerg)
RE: Printing PCBs with a 3D printer
How could you attach components, you couldn't solder?
There is a vid on Youtube of a guy who attach a photo resist pen on a bracket on the extruder.  He came to the conclusion it was a bad idea.
Opublikowany : 30/11/2019 9:36 pm
Lvet
 Lvet
(@lvet)
@towlerg you are right.
On a second thought it’s a pretty bad idea. The typical soldering temperature is 300-350C. Any type of filament would melt immediately.
Opublikowany : 30/11/2019 10:16 pm
x50arm
(@x50arm)
There is conductive filament out there:
https://www.proto-pasta.com/products/conductive-pla
Opublikowany : 30/11/2019 11:05 pm
Lvet
 Lvet
(@lvet)
It looks like a very interesting filament. I can see many of applications especially with a multi material printer
Opublikowany : 01/12/2019 7:56 am
vintagepc
(@vintagepc)
If using conductive filament you might not need to solder, perhaps it might be sufficient to just embed the leads of the component in a blob of plastic, fairly easy to do.
Opublikowany : 01/12/2019 2:22 pm
towlerg
(@towlerg)
@allen-m2
Volume resistivity of 3D printed parts along layers (x/y): 30 ohm-cm
Opublikowany : 01/12/2019 11:59 pm
Magnus
(@magnus-3)
https://addnorth.com/sv/shop/product/ANKG14BLA
The description is in swedish but it is conductive according to the site. Very expensive though.
Opublikowany : 11/12/2019 12:13 pm
towlerg
(@towlerg)
@magnus-b5
Click on the globe to select English
Opublikowany : 11/12/2019 1:40 pm
