Printing Dan's Tourbillon Mechanica or can the Y handle an additional 6mm
Denis Malyavin
(@denis-malyavin)
Hi all,
I am trying to figure out if the Prusa can print Dan's Tourbillion Mechanica.
https://www.myminifactory.com/object/3d-print-tourbillon-mechanica-tourbillon-escapement-mechanical-clock-assembly-guide-pdf-in-description-124938
The issue is that the larges base part is about 6mm to large in the Y. So, would creating a custom printer profiles based on the prusa i3 mk3s and setting the bed size in Y to be 216 (loop would have to be 0 as well) work?
Thank you!
DM
Respondido : 12/04/2021 9:05 pm
3Delight
(@3delight)
Moderador Moderator
RE: Printing Dan's Tourbillon Mechanica or can the Y handle an additional 6mm
The information is on the MyMiniFactory page you link to, under Printing details...
Respondido : 12/04/2021 9:13 pm
Baklin
(@baklin)
Have a look here.
Need to print Ø216mm footprint on I3MK3S+
Respondido : 12/04/2021 9:16 pm
Denis Malyavin
(@denis-malyavin)
Awesome, thank you all for the info, should have done a bit further searching!
Respondido : 12/04/2021 9:24 pm
