[Solved] Printer stops to unload filament
akylos58
(@akylos58)
Hi, I've been printing for a couple of months now with no big issues, but now that I've started to run longer prints I have encountered the following issue:
During printing the printer will suddensly stop in place, and I can see the "cogs" that feed the filament running in the opposite direction as if unloading the filament. Then they briefly will load again, but after a couple of seconds the head will move to the side and the printer will sound an alarm with the message: "Please press the knob to unload filament". After manually unloading and loading the filament the print usually resumes without issue.
This used to only occur now and then, but lately it occurs every few minutes, even during first layer calibration etc.
Does anyone have an idea what causes this and how I can resolve it?
Much obliged,
Alex
Napsal : 14/03/2020 10:12 am
RH_Dreambox
(@rh_dreambox)
RE: Printer stops to unload filament
You do not write which printer you have (MK3 or MK3S), but this is how MK3 can behave for certain types of filaments that the filament sensor is difficult to detect.
For these filaments it helps to temporarily switch off the filament sensor. Do not forget to activate the sensor again when changing filaments.
Napsal : 14/03/2020 10:43 am
1 lidem se líbí
akylos58
(@akylos58)
Oh, sorry! I wasn't thinking this might be a MK3 specific issue. It is indeed a MK3.
I have been reading the forums for the last couple of hours, and I've seen similar-but-not-exactly the same problem, but it all revolved around the IR sensor giving issues indeed. I have been using the same types of filament since forever though, so I wonder why it only now became an issue.
I had already set up a new attempt with the sensor off, and it is running fine so far. Let's see how this goes.
Thank you for the response!
Napsal : 14/03/2020 11:52 am
@akylos58
Sometimes dust builds up inside the mk3 sensor housing. Try air duster. There is a small hole in the midske of tge bondtech doir hinge whele you can stick the air duster tube. Its normally blocked off with a plastic plug...
Or remove the sensor and clean it...
Napsal : 14/03/2020 1:20 pm
