Print stopped with no error
Jason
(@jason-7)
So was printing a file and at a few points (randomly, as this is the 2nd time this has happened) it would stop stating crash detected.  I looked at the nozzle, no build up.  No blobs on the print.  Hit continue and it continued for another 30 mins to an hour.  This happened 2 times.  Later I come back to the print and the head in sitting on the print, the temps are still at what they should be (PLA settings) but it is not printing.  Th screen shows Prusa i3 MK3S is OK.
The first time this happened yesterday it stopped at 64.10 mm.  This time it stopped at 71.90mm.  I have never experienced this before, though I have never printed something with this overall volume (19cm wide by 12cm tall, x 7cm deep).  I cannot continue the print, and there seems to be no option to do much.  If I push in the button I only get the following options:
Tune
Statistics
Fail stats
Support
There seems like nothing I can do but shut down.  the last time I followed some instructions on resuming the print, but when I tried that there were 2 major issues with what 3 different online people were saying.  1st, I had to reset home.  Without doing that, after a power cycle, the print head assumed it was at z=0 when it was not...  None of them said anything about this, but fine, I figured that out.  Good thing the print wasn't in front of the home area....  That was fixable, but the 2nd issue was not.  The x (left-right) was offset for some reason.  It started to print about 5mm to the left of the actual print.  I don't understand that at all, but just wanted to point this out as well.
This print was to take about 8 hours printing in PLA.  Prior to this I was able to print a similar file (had to adjust the mesh at the bottom adding a tab hole I missed but that is down by the 6mm level) without this issue, though it did 'detect a crash' once.  Before that I printed a mask in PETG that took 13 hours without issues.
Between the PETG and PLA I did (as I usually do) run a cleaner filament through the printer.  I cannot say I am a Prusa guru, but looking online, I can see no issues like this...  I have just wasted 1/2 a roll of filament and 2 days with no clear reason for this problem...
Opublikowany : 18/10/2024 10:58 pm
What does the printer's fail stats log say (LCD menu)?
With the power off, move the axes by hand; are they smooth? Does the resistance stay the same over the whole range?
Clean and lubricate the smooth rods, check they are not damaged/scratched. Check the idler pulleys are not clogged, out of line, or damaged (loosen the belts and try turning them with your fingertip, are they smooth?)
With the belts loose try turning the stepper motors by hand; are they smooth?
Retighten the belts until they just begin to make a low musical note when plucked...
If the printer works, make your next print this:
https://www.prusaprinters.org/prints/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
It MUST be printed in Prusament PETG or the spring tension will be wrong.
Let us know how you get on.
Opublikowany : 18/10/2024 11:46 pm
Artur5
(@artur5)
FWIW   I printed this tension meter in Prusament PETG and afterwards, out of curiosity, I printed another from Geeetech PETG. Both gave exactly the same value. Who knows about other brands, but I suspect that most PETGs would give similar results. Possibly it depends more on print parameters (nozzle temp. etc.) than on the filament brand (just my guess..).
Opublikowany : 19/10/2024 8:06 am
RedDawg
(@reddawg)
RE: Print stopped with no error
I suspect the SD card lost contact. Start a test print and let it print for awhile. Then pull the card out intentionally. If you get the same results, that's a good indication of the cause. I can't find the link right now, but there is a shim you can print to add to the card socket that will help it maintain contact.
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Opublikowany : 19/10/2024 12:02 pm
SpectraV3i
(@spectrav3i)
I get the same with one of my printers. I finally just disabled crash detection. This is before and after a full rebuild with new rods, new bearing, all bearings aligned correctly, y Axis bed carriage bearings are correctly tensioned with the clamps, belt tension all good. All calibrations pass and are good. All bearing run smooth and are greased correctly. I have not changed the panic cable yet. I have also did factory resets, and updated FW from 3.9 all the way though to current with a Factory Reset between each  upgrade. It still did it.
I call them "False Crashes"(Y Axis). No blobs, no bumps, no layer curling, no steel sheet misalignment, nozzle clean(Revo). One day I might just replace the power panic cable. Ohh and all cables connecters seem good and well seated. Fuses all good and seating well. No Zip ties hitting anything.
This post was modified 2 years temu by SpectraV3i
Opublikowany : 19/10/2024 12:42 pm
RedDawg
(@reddawg)
Did you check the SD card socket?
Opublikowany : 19/10/2024 12:46 pm
SpectraV3i
(@spectrav3i)
IN what way? Trying different SD Cards? I have printed from SD Cards and I have more than 4. I mostly use Prusa Connect/PrusaLink.
Opublikowany : 19/10/2024 12:50 pm
RedDawg
(@reddawg)
Does the failure happen only when using SD cards or anytime randomly?
Opublikowany : 19/10/2024 1:09 pm
SpectraV3i
(@spectrav3i)
For me it is SD Card or connect or prusalink, even with no card. Although I have not fully tested this,as it will take many hours and much filament.
Opublikowany : 19/10/2024 1:15 pm
RedDawg
(@reddawg)
Confirming that it happens with other than the SD card would be helpful.
Opublikowany : 19/10/2024 1:19 pm
RedDawg
(@reddawg)
A test for a possible developing card slot problem is if the card is not recognized and read immediately when inserted. If you have to "fiddle" with it to get it to read, you need the socket shim. Sorry, still looking for the link.
Opublikowany : 19/10/2024 1:38 pm
RedDawg
(@reddawg)
Found it:
https://www.printables.com/model/15388-prusa-mk3-sd-card-slot-fix-not-reading-the-card-at.
Crap, link is broken, maybe somebody can recover it.
This post was modified 2 years temu by RedDawg
Opublikowany : 19/10/2024 1:46 pm
SpectraV3i
(@spectrav3i)
Mine works immediately. Idk about the OP though.
Opublikowany : 19/10/2024 1:47 pm
RedDawg
(@reddawg)
Try this:
Opublikowany : 19/10/2024 1:58 pm
Jason
(@jason-7)
So I think the issue is tension (what is making the false crashes) but to be sure I have taken off the top of my enclosure and put back on 'handle' spool holder that came with the printer.  I am printing now and will have to wait till it gets up around 60mm height, but so far I am not hearing the squeaking that is probably from the printed grommet for the Lack enclosure.  I am wondering if that is also adding to the 'twisting' of the filament, as it is coming through as I notice that it starts to twist a bit inside the enclosure (seen if I pull excess through, one of the things I was trying to see if helped).
In my case I don't think it is the SD card.  I have used this card on a longer print (over 14 hours) previously with no issues.  I did see that in the fail stats, that it showed like 28 crashes I think?  I am wondering if there is a crash limit before it stops.
Its just really odd that at the final fail point, most options on the screen are not available.  Such as unload, or pre-heating.  I had to power cycle it for it to fix.
One last thing, I was able to get this last fail to finish working on the G-Code.  It seems that the first layer it prints after this fail is offset by a bit (both x and y) but after the first layer put down, it went back to the right location and the rest printed fine.  Just need to cut off that .3mm bump around 2 sides, which is fine.
All and all very frustrating after printing for over a year with no issues.
Opublikowany : 20/10/2024 3:24 pm
RedDawg
(@reddawg)
I agree, it's probably not the SD card per se, but don't overlook the socket itself. If the insertion pressure between the card and socket is the least bit flakey, even minor jarring of the frame or acceleration forces during fast moves could be enough to cause a spurious, momentary disconnect between the two. Do the intentional pull-out test on a "scrap" print and see if you get the same "halting" behaviour.  If you do, try the shim fix I gave above. (The second link works.)
Opublikowany : 20/10/2024 3:58 pm
