Print Quality Question
I've tried every setting I can think of to improve the support so areas where part of the print overhangs. I keep getting these effects. (See attachments). I've tried the detail setting in the slicer, layer thickness to .1, slowed the print down by 5%, increased the support angle. Using a .4mm nozzle and PLA filament. Is there some setting I may be overlooking or is this the best I can expect? I have an I3 MKS printer. Thank you.
Opublikowany : 05/09/2020 5:57 pm
