Print Neogeo Arcade cabinet (bigger one)
bidibule
(@bidibule)
Hi All !
I found this object on thingiverse and I can't wait to try printing it !
https://www.thingiverse.com/thing:3011330
As the creator says, it will take really a lot of time for big parts so I don't want to mess up when starting.
My questions are:
* What parameters would you set for the big part and especially the curved one ? Speed, quality, etc... With Support on it ?
I don't want to mess the curve 🙂
* What filament to prefer ? PETG, PLA, ABS (haven't really mastered yet ABS)
* Any tips & tricks ?
Thank you !
Postato : 27/07/2018 12:10 am
Rosparovac
(@rosparovac)
Re: Print Neogeo Arcade cabinet (bigger one)
France sites, wow. They dont suggest anything, so there is some points from me:
PLA can melt around RPI or other electronic. My RPI 3 have in open air 85°C on CPU. Same problems is with power source. So PLA is out of choice (if you dont like multi materials building)
IMHO chose between ABS and PET(G) is 95% ABS. But I have mastered ABS and dont masterered PETG. With ABS you will probably have some arouse problems, before you find optimal setings. You have to use enclousure, Aceton....
University: MK2S upgraded to MK3 with MMU2.0
Home: MK3
Materials: ABS; ASA; PETG; PET; PLA; Nylon; Nylon Carbon; CPE;
SW: Freecad 0.18; Slicer PE And still generating more troubles than whole forum together.
Postato : 30/07/2018 1:24 pm
Martin Wolfe
(@martin-wolfe)
Extrudr's Greentec Pro might work. Not to sure it will handle the mechanical loads though as mechanically it is identical to PLA. My feeling would be one of the higher temperature PETGs.
Regards,
Martin
Martin Wolfe
Postato : 30/07/2018 2:14 pm
