Print getting bigger at height
Hey, I'm currently printing a Part which should withstand 10 bars of water pressure, so I'm using this type of setting.
I'm printing on a Prusa Mk3s with mmu2 and using aside from the changes in the pictures the default settings for a 0,4mm nozzle with 0,2mm layer height Also, I'm working with Sunlu PETG filament at a 1.1 extrusion factor.
By printing the part, it gets wider with gaining height. I have tried changing the extrusion width for the top massive infill to standard and switched on the print outside parameter first option. But this didn't changed much, as you see in the pictures.
the top of the print is left on the pictures:
before enabeling print outside parameter first:
After:
May someone have any tips to get this print done properly?
