Print Fan Error when printing one STL
michael.n24
(@michael-n24)
I am getting a Print Fan Error after the first layer or so with one particular STL sliced in SlicerPE. I know the printer works fine as I have printed other things also sliced with this version of SlicerPE (v1.41.2). It just seems that for some reason the command to start the cooling fan is never executed. I generated this STL as a cut I made in SlicerPE from a larger STL. Would anyone know why I am having problems with this STL and what I can do to fix it?
I have attached the STL and the GCODE file if it helps. Thank you.
Respondido : 10/12/2018 8:52 pm
