Print Bearing6 with NGEN
With the Prusa i3 mk3 I can easily print the Bearing6 in PLA, but printing with NGEN is an issue.
Loads of spiderwebs (hairstrings), bobling surface and some warping (at higher fan speeds).
And never had the ability to rotate the gears (except in PLA).
First print with standard Colorfabb NGEN INI settings, but changing temps, multiplier, retraction, fan speed a.o. didn't solve much.
Even printing the Frog is hairy.
Any suggestions?
Veröffentlicht : 03/10/2018 1:13 pm
