Print Artifact on Vertical Walls
Dewey79
(@dewey79)
Has anyone else seen these kind of artifacts on vertical surfaces? Still haven't gotten rid of it.
Postato : 28/05/2018 2:25 am
Gato
 Gato
(@gato)
Re: Print Artifact on Vertical Walls
Do you have crash detection on? What do you see in the last print stats failures? A crash detected could do that.
Postato : 28/05/2018 3:30 am
Dewey79
(@dewey79)
During this print I was using 3.1.3 and crash detect and filament sensors were off because that what was recommended at the time. I plan on printing this model again in another color of PLA when I switch back to 3.2.1 or newer version.
It's odd that ever other line is darker than the one between them as I would think they would all have the same distinction. I just now thought that it might be based on how each layer changes direction.
I just looked on the back side of where you see these lines and they are almost not noticeable.
Postato : 28/05/2018 3:45 am
