Pre-heat temp selection when changing filaments.
If you are changing filaments from PETG ( last Print) to PLA ( this print) do you use the higher PETG pre-heat temp when loading filament to clear any PETG that may be in the nozzle or does it clear using PLA temp?
Veröffentlicht : 22/07/2019 12:58 pm
RE: Pre-heat temp selection when changing filaments.
Yes. And many use cleaning filament to ensure the last batch is fully out of the nozzle.
Veröffentlicht : 22/07/2019 2:49 pm
