Porous Sections in Print that break and detach easily
Agentschlegel
(@agentschlegel)
Dear 3D Printing experts,
My MK3S comes up with some really bizzare prints.
I am printing sections of a wing vertically, which I have done in exactly the same way before.
Only now there appear to be "porous" sections of poor to non existing layer adhesion.
Print is PETD 0,3mm Layer height....15%Infill and 2 Outer Layers....nothing crazy.
Only change I made recently is moving to a textured sheet and hence I adjusted the Z Layer 0,2mm downwards.
Any Ideas?
Best regards
Björn
Este debate ha sido modificado el hace 8 months 4 veces por Agentschlegel
Respondido : 14/09/2025 7:52 am
Robin_13
(@robin_13)
RE: Porous Sections in Print that break and detach easily
It looks like it is under extruding for part of the print.  Did you calibrate the filament? Was the roll sticking someplace?  Are your extrusion gear teeth clean and aligned properly with the proper tension?  Do you need a new nozzle?  I don't have enough experience to advise on any issues with the head itself.
Respondido : 20/11/2025 4:42 am
Try a cold pull - this might be a partial clog.
Respondido : 20/11/2025 6:31 am
