Pimply first layer
MMPLLC
(@mmpllc)
Pimply first layer
Guys,
I “recently” installed a PCD nozzle on my Mk3/MMU3. After sorting things out, I’m getting a really rough first layer:
The print ends up fine, with everything after the first layer coming out smooth, and a smooth final result. But that first layer has me baffled. I wasn’t getting this with the stock brass nozzle.
What gives?
Thanks. Brad.
Este debate ha sido modificado el hace 2 years 2 veces por MMPLLC
Respondido : 29/06/2024 3:47 pm
Tim Weston
(@tim-weston)
From the picture, the nozzle is too low and is dragging through the already extruded material on the bed. Did you redo the first layer calibration after changing the nozzle?
You always need to do that, even when changing for a nozzle of the same type.
Cheers,
Tim
Esta publicación ha sido modificada el hace 2 years por Tim Weston
Respondido : 30/06/2024 7:12 am
MMPLLC
(@mmpllc)
RE: Pimply first layer
Tim,
Thanks for the response. That has been my thinking.
Yes, I recalibrated the Z, but it’s very likely it’s still too low. I raised the Z-adjust once, but it didn’t get better. I only raised it a tiny bit, so it could be that it wasn’t enough. Next print, I’ll raise it again and check back.
Respondido : 30/06/2024 12:41 pm
