PETG way off
mbuto
(@mbuto)
PETG way off
Howdy,
All my PLA print jobs are fine - but I need a couple of things in PETG and everything is way , way off! Can you diagnose this?
Thanks,
Mike
Postato : 05/07/2021 8:26 pm
ssill2
(@ssill2)
RE: PETG way off
Ive found that pla and petg often require different zoffets.  I set up separate steel sheet profiles for pla and petg.  Tpu even has a different z.  Create a 75 or 100mm .2mm high test square and calibrate each sheet profile separately.  Petg is usually less negative I.e further from the plate
Postato : 06/07/2021 12:28 am
Utenti
RE: PETG way off
@ssill2
Agree.  We need a first player calibration print to help.
Postato : 06/07/2021 12:30 am
mbuto
(@mbuto)
RE: PETG way off
No joy. What you see is a range of Z offsets. Even when I got one fairly close, it still had this pulsing effect throughout.
Postato : 09/07/2021 11:11 pm
ssill2
(@ssill2)
RE: PETG way off
Petg needs to be higher generally than pla on the same plate.  The textured plate definitely likes petg as long as it’s clean
Postato : 09/07/2021 11:49 pm
Swiss_Cheese
(@swiss_cheese)
RE: PETG way off
Posted by: @mbuto
your waaay to high, lower the nozzle
The Filament Whisperer
Postato : 10/07/2021 2:32 am
mbuto
(@mbuto)
RE: PETG way off
Sorry if I wasn't clear earlier, but this is just the worst of it - at the Z level suggested by others. It seems like no Z level will work. What seems to happen is those lines of excess material across the direction of the print. Look at the right side. See how very little material is laid down, then splat! a big blob as the direction reverses, then back to almost nothing. Then a hiccup of material, then too thin, etc. etc.
Postato : 10/07/2021 3:06 am
Lize
 Lize
(@lize)
RE: PETG way off
Are you sure you've selected a suitable PETG profile in slicer?  Looks like the temperature could be too low given the poor extrusion, I'd double check the recommended settings of the filament.
Postato : 10/07/2021 12:01 pm
1 persone hanno apprezzato
ssill2
(@ssill2)
RE: PETG way off
@lize
I agree.  if you zip up your .3mf file and attach it here we'll be able to see what temps you are trying to print with.
Postato : 10/07/2021 12:37 pm
John
 John
(@john-6)
RE: PETG way off
@mbuto
In my limited petg experience I found that when the z is too high the filament has nowhere to go but back onto the nozzle. This results in the excess finally depositing on the print or worse catching the print and lifting it.
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Postato : 11/07/2021 12:28 am
