Petg first layer after supports
Magnus
(@magnus-3)
Hello,
I am printing a custom designed mounting thing for a ubiquiti camera. The middle part of this is a 10mm cutout which is filled with supports. The first layer after the supports didn't stick to the supports and caused a lot of noice so I canceled the print since it would not turn out ok anyway.
I think I will redesign the part so that I screw the bottom ring onto the top part so I can print both parts flat to the bed.
But anyway what settings should I tweak to get rid of this behaviour perhaps raise the temperature? Petg seems harder to print than pla but this part is for outdoor use so I cant use pla for this.
The temperature was standard prusa petg which is first layer 230 bed 85, the rest of the layers 240 bed 90. Filament was prusa petg.
Thanks in advance
Magnus
Veröffentlicht : 02/06/2018 1:04 pm
Joe Prints
(@joe-prints)
Re: Petg first layer after supports
You can try lowering the Contact Z distance in print settings to 0.1(what I use) or raise the Interface pattern spacing to make the top of the supports smoother and easier to stick the next layer onto.
Both settings are found in Print Settings tab> Support material of Slic3r PE
Anything can be made better
https://www.myminifactory.com/users/Joe%20Prints
Veröffentlicht : 03/06/2018 2:14 pm
Magnus
(@magnus-3)
Thanks.
Will try that.
Veröffentlicht : 06/06/2018 7:08 pm
3dprinteruser
(@3dprinteruser)
RE: Petg first layer after supports
Currently I’m having same issues with petg did you resolve the problem ?
Veröffentlicht : 16/01/2022 9:59 am
ssill2
(@ssill2)
I do a lot of petg printing with supports.  I've found that petg with a ton of supports prints WAY better hotter, like 250 or 255.  it has less tendency to to drag the supports, which are by default thinner extrusions.
Veröffentlicht : 16/01/2022 2:53 pm
3dprinteruser
(@3dprinteruser)
Thanks @ssill2 ,  I have increased the nozzle to the 255 from 240 (Contact z was already 0.1), lets see if this is going to work better or not. I'm very happy with overall print but it is really noisy first level after supports as the original post sender already mentioned.
Veröffentlicht : 16/01/2022 3:35 pm
ssill2
(@ssill2)
I came to the realization a month or two ago that the 230/240 default for prusament PETG really didn't work well at all for supports.  It seems like the less viscosity of the hotter filament really keeps the support extrusions from getting dragged as the nozzle moves.  I'll be interested to see if you have similar experience.
Veröffentlicht : 16/01/2022 3:38 pm
Mclayne
(@mclayne)
how much should I raise the interface pattern spacing?(right now it's 0)
Posted by: @joe-prints
Veröffentlicht : 17/01/2022 8:33 am
