Perfect until a certain layer height. Then THICK strings
[Rozwiązany] Perfect until a certain layer height. Then THICK strings
fhatinthehat
(@fhatinthehat)
Thick strings - PETG, .2 layer height .4 nozzle
Best Answer by --:
The print result will depend on how thick the layers are when you slice. 0.20 looks marginal; 0.15 layers look okay - sort of.  Are you using Detect Bridging Perimeters when you slice?
Printing these spots too fast will cause layer adhesion issues ... the new layer won't stick to the prior layer ... the strand pulls free and you get the rubber band effect in the images.
Opublikowany : 20/09/2019 6:58 am
Bunny Science
(@bunny-science)
RE: Perfect until a certain layer height. Then THICK strings
Is there a circular overhang at that level in the model? It looks like an interior ridge is at that level. There is such a feature in the larger portion as well. If interior ridges are not designed with a printable, bottom chamfer, the printer will be printing in mid-air and leaving such strings as it tries to lay down a circular ridge in mid-air.
Upload your 3MF or model file and we can inspect for the issue.
Opublikowany : 20/09/2019 12:00 pm
1 ludzie polubili
fhatinthehat
(@fhatinthehat)
@guy-k2
https://www.thingiverse.com/thing:903411
This is the water reservoir from the self watering planter. I think you might be right. The larger ID had an overhang and thick stringing as well. I just cut them off before posting. Hope this helps
This post was modified 7 years temu by fhatinthehat
Opublikowany : 20/09/2019 2:33 pm
This post was modified 7 years temu by --
Opublikowany : 20/09/2019 5:41 pm
Bunny Science
(@bunny-science)
Agreed regarding printing this sliced at 0.15 mm. The thinner slice will let printer have better chance of doing the overhang successfully.
Opublikowany : 21/09/2019 9:03 am
1 ludzie polubili
fhatinthehat
(@fhatinthehat)
Thanks for the help guys! I’m going to try this again with .15 and see how I do
Opublikowany : 21/09/2019 3:26 pm
