PC Overhangs
Lukas
(@lukas-6)
PC Overhangs
I wanted to try some new material and decided to go for PC. The one I am using currently is Polymax PC. I am using an adhesive designed for PC to counter the adhesion issues which worked out great and simple objects look good.
However once I went for something with overhangs, even easy ones look really terrible (see attached picture of a calicat). I also get quite a lot of stringing but I guess I have to increase the retraction a bit.
Settings:
.2mm layer height (same problem with .15)
110° Bed / 260° Nozzle (in enclosure)
30-50mm/s
10% cooling, 30% for bridges
.8mm retraction
What would you suggest to try to counter that prolem?
Posted : 30/03/2022 9:07 am
