PC Blend without warping help
chmax
(@chmax)
Hi, if someone out there is able to print a relatively small (5cm x 15cm) PC Blend part without warping, could you please share with me your setting? I am using the satin sheet with glue and some "tabs" at the one end of the model (standard .4 nozzle and 0.15 quality setting) but I still get warping. I am using a Prusa enclosure.
Anticipated thanks!
Veröffentlicht : 16/08/2023 2:52 pm
