pauzing print for filament-change in Slic3R
I prefer the detailed control in Slic3R.
Sometimes PrusaControl is just too basic.
Is there a way to implement a or some pauze(s) to change filament ... in Slic3R.
I know this is very easy in PrusaCOntrol, i've used it allready ... but looking for the same procedure in Slic3R.
thx for the help.
Respondido : 18/06/2018 12:57 am
Re: pauzing print for filament-change in Slic3R
You can create your gcode in Slic3r and then import it into PrusaControl to add your color changes.
Respondido : 18/06/2018 3:44 pm
Or do it by height using this: https://www.prusaprinters.org/color-print/
You can check the height in the "layer" view in slic3r to make sure you add the change where you want to.
Respondido : 19/06/2018 6:28 pm
