Parts missing in conversion from stl to gcode
Fiddledeedee
(@fiddledeedee)
Hi everybody,
I've created a spare part I need in Autodesk Fusion 360, exportet it as stl and used Prusa Control to create the gcode file.
Unfortunately most of the model is omitted during conversion. I've already tried the Slicer program instead with the same result, so I guess it's kind of my mistake, but I don't know what.
When loading the STL file into Prusa Control the preview it shows looks just what I want, then I run the gcode conversion and load that gcode file again. It looks wrong. I've attached two files, one with the preview, one with the result.
Can anybody point me in the right direction?
Opublikowany : 10/02/2019 2:59 pm
Fiddledeedee
(@fiddledeedee)
Re: Parts missing in conversion from stl to gcode
I've fiddled with the project a bit. Eventually it worked, don't know what it was unfortunately.
Opublikowany : 11/02/2019 7:43 pm
