part has partial lattice in bolt holes
john.d57
(@john-d57)
I am printing a part for an actuator from an STL file. When I run it thru the Slic3r-PE the part shows lattice in the bolt holes. It is only partially filled but it should be clear. What setting do I modify to get clear bolt holes. This happens on several parts on bolt holes of 4,5,&6 mm.
I am very new to printing and lost on how to eliminate the lattice.
Napsal : 03/04/2019 2:14 am
RetireeJay
(@retireejay)
Re: part has partial lattice in bolt holes
It may be that the STL file you are using is not perfect. Google Netfabb and use its free service (either online or on your computer) to check the STL for errors. Netfabb can usually fix the errors.
Napsal : 03/04/2019 3:21 am
