PA6-CF long stringing with Travelmoves
Ennox
(@ennox)
Hello all,
Currently, I am trying to print with 3DXtech PA6-CF filament using my Prusa Mk3a/+ printer which has been modified with a Bondtech Extruder and the Slice Magnum. I am printing inside a Prusa Original Enclosure.
I have dried the filament for 9 hours at 50 degrees Celsius and I am trying to print it with temperatures ranging between 240 and 270 degrees Celsius, as recommended by the manufacturer.
However, the filament always drips out of the nozzle when traveling, despite trying different retract settings. I am unsure of what the problem could be at the moment.
Does anyone have any ideas?
Ennox
Opublikowany : 20/02/2023 3:48 pm
aaron bastian
(@aaron-bastian)
RE: PA6-CF long stringing with Travelmoves
Were you able to solve this? I am struggling with similar issues printing PA6/69 without CF. Printing at the manufacturer's recommended settings + messed around with the retraction settings to no avail.
I am running a QIDI tech X-MAX3 at 255 nozzle, 55 bed, and 50 chamber.
Opublikowany : 07/12/2023 5:55 pm
