Overture PETG (black) settings for MK3S+
This is my suggestion for printing with Overture PETG (black) 1.75mm in the UK using the MK3+ with 0.4mm nozzle, 0.2mm layers.
The manufacturers recommended temp is 230-250 deg C. However, I tried all sorts of temp settings (based on Prusament PETG default settings) within this range on my Mk3+ and always ended up with bogies and blobs:-(
Daring to go outside the manufacturers recommended temp range, I tried 260 deg C. This sorted out all the blob issues. See attached image for filament settings.
Hope this helps someone....;-)
Postato : 05/09/2023 10:15 pm
