Over extrusion on benchy smokestack only
3D Endeavors
(@3d-endeavors)
The rest of the print looks fine. I just upgraded to the misumis rods and bearings redid my calibrations and when all seemed well I tried a benchy. Stock prusa slicer settings.
I have had many successful benchy prints and non with this issue let alone at this particular spot alone.
Thanks for any help!
Best Answer by 3D Endeavors:
Turns out my nozzle or heat break had vibrated loose and was causing some funky issues. Totally unrelated but I also seemed to have sorts fixed the muu2s fail to load issue by unscrewing the IR sensor and turning it towards the flag on the idler door then retightening it. A little over halfway through a print with about 30 tool changes and no manual intervention
Publié : 01/02/2022 3:02 pm
3D Endeavors
(@3d-endeavors)
RE: Over extrusion on benchy smokestack only
Publié : 02/02/2022 2:42 am
Bob
 Bob
(@bob-2)
Glad you found it, from what little I can see of the rest of the benchy it looks pretty good.
-Bob
Publié : 02/02/2022 3:23 am
3D Endeavors
(@3d-endeavors)
Thanks! I'm very very happy with the results so far since the upgrade to the misumi rods and bearings. Ghosting is almost entirely gone and I can hear my clock tick over the printer when the house is quiet haha.
I am also just baffled that the slight IR sensor adjustment seems to have fixed all my woes with the mmu2s. That print finished no problems and looks great I think.
Publié : 02/02/2022 4:01 am
