Oozing is ruining my TPU gasket, anyway I can optimize this further?
I know TPU is difficult to print and, all things considered, this isn't a terrible result. The problem is, the oozing is occurring over the channel where my part needs to fit flush in order to create a seal. I'm using Sainsmart TPU (95A) and I'm using the matching profile inside of PrusaSlicer on my mk3s. I've tried tweaking a bunch of things:
- Checking 'Avoid crossing perimeters' doesn't seem to do anything
- I've tweaked all kinds of retraction settings, increasing length from 1 to 1.5mm, messing with the retraction speed, increasing lift Z (default is 0), and ultimately the settings in the profile seem to work best (go figure). I'm sure there is more I could do here though--it seems like a retraction problem?
- Nozzle temp is 230, which seems inline with what people recommend to prevent oozing.
- I've slowed speed waaayyy down, like 10mm/s for print moves and travel moves. This helps somewhat but pretty much gets the result you see below.
- Speaking of travel, I wish there were a way to optimize travel in PrusaSlicer. Maybe there is that I don't know about. But 'Avoid Crossing Perimeters' seems to do little to nothing, a complaint I've seen elsewhere. Is there something I'm missing here? Perhaps I could try a different slicer, optimize the travel, and avoid the oozing over my channel?
Any ideas would be very much appreciated!
RE: Oozing is ruining my TPU gasket, anyway I can optimize this further?
Post your .3mf lets see what you got.
The Filament Whisperer
Working on that now!
ok
Here's it is..
gonna take look ill get back to you.
Try this, I would like to remind you that TPU is extremely hygroscopic if yours is not dry you are going to have stringing issues.
8 minute print let me know how it goes, I normally like to try before I send but all my printers are busy sorry.
Good luck hope this helps
Swiss_Cheese
This is extremely nice of you, thank you! I tried to slice the 3mf and got a "PrusaSlicer has encountered an error":
"G-code export to /var/folders/82/wksgwkmj6bv9vvvc3d4sh9dr0000gn/T/.75797.gcode failed due to invalid custom G-code sections:
end_gcode
Please inspect the file /var/folders/82/wksgwkmj6bv9vvvc3d4sh9dr0000gn/T/.75797.gcode.tmp for error messages enclosed between
!!!!! Failed to process the custom G-code template ...
and
!!!!! End of an error report for the custom G-code template .."
I don't know much about G-code or I'd have a go. Any ideas?
I should also add, my TPU is stored at ~20% humidity. I've heard from others that should be fine, do you think so as well?
I was on PS 2.2 and just upgraded to 2.3.1. It seems to slice fine there. I'm going to give it a go! Thanks again.
I've never hear that one before, what version of slicer are you using? this was produced in 2.3 for mk3s & mk3s+
ok sorry I was late to the party : )
the speeds at which you were printing, that was the biggest. I would Urge you to examine the .3mf and compare it to the one you were using to explore the differences.
I'm glad I was able to help,
Swiss_cheese
