Nylon help
MK3S+
Pretty new to nylon, and I've been reading up here and the wider interwebs.
Read the Matterhackers article, which I found helpful.
I'm using Fiberthree F3 PA-CF Pro 15% Carbon fiber Filament from the Prusa website and following their specs.
No bubbling or popping, so I think I'm fairly dry.
Using the satin steel sheet that came with the printer, my bed adhesion is great. I print in a small closet with multiple printers, so the temperature stays constant. However, my layer adhesion is terrible. My parts are brittle and split lengthwise between layers. What am I missing?
Opublikowany : 17/11/2022 5:37 pm
