Need help with printing a high-resolution model in multiple colors
julian
(@julian)
Hi friends!
I'm ordering a 0.25mm nozzle to print in high resolution. I'm trying to print a dogtag for... my dog!
I have created a model with the text missing from the first layer, and I'd like to print that layer first in a different color. Is it possible to configure Slic3r to first the text, do a filament change, and then print the rest? I currently have both models overlapped in the plater view, but it's complaining that the objects are too close.
Does anyone have any tips/tricks on accomplishing this? Also, does anyone have a good reference for setting up Slic3r for a 0.25mm nozzle?
Thanks!
Opublikowany : 13/03/2019 10:33 pm
vintagepc
(@vintagepc)
Re: Need help with printing a high-resolution model in multiple colors
Why yes:
https://shop.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles--f65/simple-way-to-print-in-real-multi-color-without-mm-t28186.html
There should be a 0.25mm profile in Slic3r PE, have you tried importing that?
Edit since I'm marking this post as an answer: Configuration->Configuration assistant. Under your model there will be a choice for a 0.25 nozzle.
Opublikowany : 13/03/2019 10:35 pm
julian
(@julian)
Why yes:
thanks for the link!
I don't know where / how to import the profile... I'm kind of new to Slic3r 😕
Opublikowany : 13/03/2019 10:42 pm
vintagepc
(@vintagepc)
Why yes:
Opublikowany : 14/03/2019 2:49 am
julian
(@julian)
Why yes:
Thanks!
Opublikowany : 14/03/2019 6:03 pm
