Need advice what I should adjust to get clean print
Kraut55
(@kraut55)
I printed this Voronoi ball with my MK3S at 0.15mm quality. Different materials (FLEX and TPU) show the same results. During the print I changed the print speed to 80% and later to 120% but that did not change the print.
Which settings should I try to get a clean print?
Napsal : 30/09/2020 12:10 pm
RE: Need advice what I should adjust to get clean print
Try increasing your retraction.
Napsal : 30/09/2020 6:26 pm
Nikolai
(@nikolai)
There is not much you can do. Any flexible material generates strings. I'm glad you were at least able to print such a thing in flexible material 🙂
Increasing the retraction (or better set higher K-value in linear advance) might work but you're also increasing the risk of failed print.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Napsal : 30/09/2020 8:51 pm
Peter M
(@peter-m)
Begin with a temp tower.
Begin with printing a string test model.
Napsal : 01/10/2020 8:14 am
I would also say that a temptower is the best way to estimate and influence what is happening. With every new filament I perform a "temptowercheck". Usually there is always something to optimize.
https://www.thingiverse.com/thing:2318636
Napsal : 01/10/2020 8:29 am
Kraut55
(@kraut55)
Thank you very much for your fast replies. I'll  try your suggestions and come back later.
Napsal : 01/10/2020 3:03 pm
Kraut55
(@kraut55)
Temp Tower did not really help. The best temp in PLA was 190°. The ball still looks the same.
Will check the other suggestions
Napsal : 14/10/2020 1:00 pm
Andrew D.
(@andrew-d-2)
What is the exact material you are printing with? I find that when printing with a set material like fiberflex or Ninjatek I followed what the manufacturer has on the package and slowed it down even more. I also replaced my bowden tubes to keep the filament from binding on the retraction if you dont have a mmu2s.
Napsal : 14/10/2020 2:04 pm
