Multiple height with same parts
SergePix
(@sergepix)
Hello,
I would like to print a part with 2 differents qualities.
I have a part that I want to print in .20mm and on top I have text that I would like to print in 0.10mm.
Is it possible to print 2 differents heights on the same part?
Publié : 24/11/2024 10:07 pm
RE: Multiple height with same parts
Yes,
use  height range modifier
I have enclosed a project file i a zipfile, below
Publié : 24/11/2024 11:47 pm
SergePix
(@sergepix)
Hello Joan,
thanks for the suggestion.
What is your suggestion to improve the printing of numbers and letters. I tried the height from .2 to .1 but it is not always clean. I take the character size of 14 points
Ce message a été modifié il y a 10 months par SergePix
Publié : 26/11/2024 10:18 am
Hi Serge,
14pt is quite a small type size.
to maximise your chances of good resolution,
use a 'San Serif' type style such as 'Arial' (Bold) or 'Arial Black'
If you can, use all Capital characters.
reduce the number of perimeters to one (to allow the maximum space for infill)
on the example that I used, I set the slicer to use a single perimeter on all top layers
for small text I would consider reducing the perimeter extrusion width on the top surface, to  the nozzle size, to maximise the space for infill...
Publié : 26/11/2024 11:31 am
SergePix
(@sergepix)
Hello Joan,
Thank you for your help. I will try it!
Publié : 28/11/2024 10:54 pm
Best Wishes
Joan
Publié : 28/11/2024 11:04 pm
