Multi part printing with different print setting Slic3r PE
arto.h
(@arto-h)
Is it possible print multi parts same time with different print setting with Slic3r PE? If its possible how it can proceed?
Posted : 11/07/2018 10:09 am
Re: Multi part printing with different print setting Slic3r PE
I believe you can use variable layer height on different models on the same build plate.
And
You can use mesh modifiers to change print parameters in different areas of a model on the build plate. Within slic3r
Regards Joan
Posted : 11/07/2018 12:46 pm
arto.h
(@arto-h)
I assume that I cannot change print temperature, like do temp tower with these settings?
Posted : 11/07/2018 1:32 pm
